Moving objects
Objects can be moved in several ways.
Use the Move command (operates in the screen plane) or Move 3D command to move an object an exact distance.
Use the Move by Points tool to move, duplicate, and distribute objects by clicking.
Use the Selection tool's Transform mode to move objects using the 3D dragger's linear, rotational, or planar controls.
Use the selection tools to select and drag objects to a new location.
Nudge selected objects one pixel at a time, or by the snap grid (see Vectorworks preferences: Edit pane).
Moving objects in the screen plane
Moving objects in 3D space
Moving objects by clicking with the Move by Points tool
Moving symbols in walls with the Selection tool
Moving symbols in walls with the Move command
Moving symbols in walls with the Move by Points tool
Translating and rotating objects with the 3D dragger
